Path of Exile 2 (PoE 2) introduces a wealth of innovative mechanics, and Elemental Invocation stands out as a powerful meta spirit gem that can transform your elemental build. Designed for players who harness fire, cold, and lightning damage, this skill revolves around energy collection and spell triggering, offering unparalleled flexibility and damage potential.
Whether you're a seasoned exile or new to the game, mastering Elemental Invocation requires understanding its core mechanics, acquisition, and optimization. This guide breaks down everything you need to know to use Elemental Invocation effectively, from unlocking it to dominating combat with its unique synergies.
1. What Is Elemental Invocation?
Elemental Invocation is a persistent buff skill in PoE 2 that focuses on elemental ailments-freeze, shock, and ignite-to generate energy. Once enough energy is gathered, it consumes that energy to trigger socketed spells, even multiple times if energy allows.
Unlike standard skills, it acts as a meta gem, meaning it supports and enhances other spells rather than dealing direct damage on its own. Its versatility makes it a staple for any elemental build, whether you're a damage dealer, tank, or support character.
Key basics: It requires 60 spirit reservation, level 26, 34 Dexterity, and 34 Intelligence to use. Its maximum base energy is 500, and quality can increase this by up to 100 additional energy.
2. How to Acquire Elemental Invocation
Before using Elemental Invocation, you must craft it by engraving it onto an uncut spirit gem. This process is straightforward but requires a few key steps to complete successfully.
First, obtain an uncut spirit gem of level 8 or higher. Spirit gems level up as you progress through the game, so focus on leveling your gems alongside your character to reach level 8 quickly.
Next, access the gem cutting menu by selecting the uncut spirit gem in your inventory. Navigate to the Monk tree within this menu, then find the level VIII tier-this is where the Elemental Invocation engraving option is located.
Select the engrave option to craft the gem. Once complete, Elemental Invocation will be added to your inventory, ready to be slotted into your skill bar and linked with other spells.
3. Core Mechanics: Energy Collection & Spell Triggering
The heart of Elemental Invocation is its energy system. To use it effectively, you need to understand how to generate energy, monitor your energy levels, and trigger socketed spells at the right time.
Energy is gained by inflicting freeze, shock, or ignite on enemies with your skills. The amount of energy gained varies by ailment: 10 energy per power of frozen enemies, 1 energy per power of shocked enemies, and 1 energy per power of ignited enemies (modified by the ignite's percentage of the enemy's ailment threshold).
You can also boost energy gain with the gem's inherent modifier, which grants 0–68% increased energy gained (scaling with gem level). This makes leveling your Elemental Invocation gem a priority for faster energy accumulation.
Once you have enough energy, activating Elemental Invocation (via its icon or assigned shortcut) consumes the energy to trigger socketed spells. Each socketed spell requires 10 energy per 0.1 seconds of its base cast time, so plan your spell choices accordingly.
Poe 2 trade was amazing. He made my deal go seamlessly. He was professional and friendly. Would absolutely buy from again! You can also purchase it at MMOEXP.com
