Hi,
In last build 8536 IFC import don't work properly - profile is displaced by Z. I continue to use Robot to convert from Advance Steel-> Robot -> DXF do import in Tower 8. Transfer info for steel section is good but is not enough for complete transfer data model to other software such Advance Steel.
IFC Import
- Postovi: 31
- Pridružio se: Čet Nov 01, 2012 8:32 am
- Lokacija: Bulgaria, Varna
IFC Import
K-Engineering Varna Ltd
Bulgaria, Varna
Bulgaria, Varna
- Postovi: 31
Re: IFC Import
Maybe is good to make import option to import only 2d - and tower replace Z coordination with zero. I often make industrial platforms an such option will be very good or working ifc import.
Bulgaria, Varna
Bulgaria, Varna
Re: IFC Import
Dear Sir,
It would be very useful if you could provide us with an IFC file in which the profiles are moved in the Z direction.
Also, it would be useful if you could point out the missing data so that the IFC file from Tower can be used in Advance Steel.
It would be best if you would write to us directly at our email: info@radimpex.rs
Thank you in advance.
