problem and suggestion in Tower 7
vkrivoshiev
Postovi: 31
Pridružio se: Čet Nov 01, 2012 8:32 am
Lokacija: Bulgaria, Varna
Re: problem and suggestion in Tower 7
Post od vkrivoshiev »
hi
I have few more suggestion:
1.Can you add option like AutoCad - Match Properties - for beams and columns - for fast change ONLY sections.
2.Can you make after run command "Control of geometry" counting errors.
thank you
eng.Vladimir Krivoshiev
K-Engineering Varna Ltd
Bulgaria, Varna
Some other users also asked for "Match properties". This request is in our list, already.
Please explain - Counting errors - just as an information in dialog or something else ?
Thank You for suggestions!
vkrivoshiev
Postovi: 31
Counting errors - only for information for global errors in 3D models.(red square)
This options will be good in comparison between two models.
and two new question:
Can you add option for different concrete cover in each directions for top and bottom reinforcements?
Can you add option for reinforcement calculator - with option for docking left or right in main window?
I made such a program for me (C++ Builder)
http://picbg.net/img.php?file=2a50cf24c4d5015e.jpg
Will be very usefull option.
thank you
Bulgaria, Varna
vkrivoshiev
Postovi: 31
hi again
i have one more suggestion:
Can you add option in:
Level Edit ->to create automatic level not only for plate but and for linear and joint supports.
Often need to model divides and move plates up and then have to manually enter a new level of supports
Bulgaria, Varna
vkrivoshiev wrote:hi again
Automatic means - always.
It is more convenient for user to add some levels manually, than to delete unnecessary ones.
Deleting non empty level requires asking user to chose between deleting or leaving entities on that level.
We think that implementing Your suggestion would cause unnecessary complication and a bit of confusion.
vkrivoshiev
Postovi: 31
hi
We use new option in Tower 7 - links and see one problem. If we want to delete one link in section X1, the other link behind section X1 - in X2.....Xn will be deleted too.
Bulgaria, Varna
Yes, You are right, thank You.
We noticed this bug several weeks ago and fixed it in a new Build of program Tower 7 which will be published until the end of this month.
vkrivoshiev
Postovi: 31
hi again
can you add option in Edit Documents - button to delete all pages at once.
if i have generated 1 000 pages, drag one by one takes a little time.
thank you
eng.Vladimir Kriwovhiev
Bulgaria, Varna
Deleting large number of blocks (which will automatically delete all the empty pages) in Tower 7 is quite easy - select one block in the tree (left pane of the Editor window) by mouse left click, scroll the tree to desired place, hold SHIFT and left mouse click at the last block You want to select. All the blocks in between will be selected. Then push the button Delete at the keyboard.
If You want to delete all the blocks - select the very first block in the tree, scroll the tree to the bottom and with SHIFT pressed click on the the last block. Then pres DELETE button.
