Hteo bih da postavim pitanje:
Tower 5.XX
1.Pri modalnoj analizi, pravac delovanja zemljotersa npr sx, na nekoj etazzi, kako mogu da pronadjem taccku koja ima maximalno hotizontalno pomeranje (to je pomeranje jednako maxh=sqrt(Xp*Xp+Yp*Yp), pritom ni Xp ni Yp nisu extremi na toj etazzi). Konstrukcija niti je simetricna, niti su zidovi za ukrućenje simetriccno rasporedjeni.
Unapred Hvala
rimodar
Horizontalno pomeranje k-je
Ako je u pitanju "Inter-story displacements" cini mi se da se to mora racunati na neki drugi nacin.
Evo clanka preuzetog iz tehnicke dokumentacije uz program SAP2000 odn. ETABS
http://www.csiberkeley.com/Tech_Info/15.pdf
15.9.1 Story Drift Calculations
All displacements produced by the response spectrum method are positive numbers.
Therefore, a plot of a dynamic displaced shape has very little meaning since each
displacement is an estimation of the maximum value. Inter-story displacements are
used to estimate damage to nonstructural elements and cannot be calculated directly
from the probable peak values of displacement. A simple method to obtain a
probable peak value of shear strain is to place a very thin panel element, with a
shear modulus of unity, in the area where the deformation is to be calculated. The
peak value of shear stress will be a good estimation of the damage index. The
current code suggests a maximum value of 0.005 horizontal drift ratio, which is the
same as panel shear strain if the vertical displacements are neglected.
Da, ali ETABS svejedno izracuna ove "zamike" u obliki tabele (tacka-zamik), sto je vrlo prirucno za kontrolu po predpisima. Ako se ne varam 0.005 (horizontal drift ratio) nanasa se upravo na zamike dobijene sa modalnom analizom (samo pozitivne vrednosti) i zato i ne vidim, da bi ovo racunali na neki drugi (poseban) nacin. U seizmickim racunima sve vise se govori samo o pomicima (koje se i limitira) i sve manje o silama (naponima). Kontrola pomicanja tako postaje bitna kontrola.
